Cruise control issue.
Hello all,
I got a disco 2 se7 209000 miles. everything works except the CC. I replaced the cracked vac hose. the dash button works and I can hear a click behind the glove box when I pull the res button but nothing when I pull the set button. I've looked for the vac hose from the break pedal as recommended, but I can't find one. not sure of any other tests I can do so any info will be appreciated
Appreciate your understanding.
Others likely to have suggestions and I'll try taking a look at it later when time permits.
Do you have copies of the Maintenance and Electrical manuals from the RAVE? They are helpful in describing the relatively simple operation.
land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
so I done fixed it. new vac hoses and took apart the little motor and gave it a good clean with a quip. thanks everyone
