Sponsored by: CARiD
D2 Front Cover Gasket - Sealant?
Old Feb 27, 2014 | 01:29 PM
Krazydisco's Avatar
4th Gear
Default D2 Front Cover Gasket - Sealant?
Hello All,
I have been a lurker of the site for a while and it has been a huge help. Just replaced my heater core a few months ago with no issues thanks to the forum.
With the help of the HF Coolant Pressure Test Kit I am now tackling a coolant leak (notorious fail spot on the top right of the front cover) and was curious if I should use sealant on one or both sides of the AB front cover gasket I ordered. The gasket itself is green, and has a small black line running in the middle of one side (black line is heat activated sealant?)
I was thinking I would apply a thin layer of Right Stuff Grey on the smooth side of the gasket, and leave the black line side alone. However, I do not want to do this job again so I hesitate about putting a thin layer on both sides.
Also I will be replacing:
1.) Water Pump
2.) Timing chain/gears
3.) Thermostat and expansion tank cap
4.) Oil pump gears
5.) All related seals and gaskets (oil pan, front main, o-rings, water pump, etc)
My truck is a 2000 D2 with 140K miles, Niagra Grey, bone stock....
Thanks in advance for the wisdom
Old Apr 5, 2014 | 03:41 PM
jdwcrw4's Avatar
3rd Gear
Definitely watching this post! I am considering doing all of the same items.
Chris
Lansing, MI
2003 HSE7 Disco II
Old Apr 5, 2014 | 04:36 PM
tuercas viejas's Avatar
Hola
For this application I use a shellac based sealant like Apache from your local parts store.
I will only use Hylomar is the faces are marred by minor impact/pry damage, corrosion etc.
T/V
Krazydisco
Feb 27, 2014 05:04 PM
lipadj46
Aug 27, 2012 10:06 AM
ngarover
Apr 16, 2012 09:48 PM
zukilj20
Apr 16, 2012 10:46 AM
JimScream
Jan 6, 2009 02:01 PM
