Sponsored by: CARiD
Defender Rear Axle bearing loose
Old Oct 10, 2007 | 07:36 AM
ronane's Avatar
Default Defender Rear Axle bearing loose
Hi,
My defender recently failed it's roadworthiness test. The Tester said the rear axle bearing was loose, and that I could fit a washer to the axle that would fix this.
I'm going to try this but before I jack the jeep up and take it apart I'd like to have an idea of what parts I need and if I'm doing the right thing.
so
Does anyone know if this sounds like a good fix to the problem or should I just replace the bearing?
or
What kind of washers do I need to order.
Thanks for your help
Keep those landys rollin
Old Oct 10, 2007 | 08:40 AM
Default RE: Defender Rear Axle bearing loose
I wouldn't do it, if it is loose then pull id down, inspect and repack the wheel bearing and make sure nothing else id going on.
Grlica
May 1, 2013 06:13 PM
lost rover
Mar 31, 2013 09:41 PM
binvanna
Feb 25, 2013 11:43 AM
yoshibond
Apr 18, 2012 01:41 PM
robot808
Nov 18, 2009 11:10 PM
