Sponsored by: CARiD
Differential
Old Oct 10, 2015 | 12:05 PM
mcabrera3's Avatar
Originally Posted by ihscouts
God dang, replace the CV's and be done with it......
Last time that I removed the doferential my CVS where fine
Old Oct 10, 2015 | 12:47 PM
ihscouts's Avatar
Really, they pop when turning and that's "fine"? Ok, I'm fine with that. Good luck.
Old Oct 10, 2015 | 01:10 PM
mcabrera3's Avatar
How do you know its the cv axles??
Old Oct 10, 2015 | 02:06 PM
ihscouts's Avatar
How do you know their fine?
Old Oct 13, 2015 | 01:42 PM
mcabrera3's Avatar
I took them off and checked for any unusual movement of slip when turning.
Old Oct 13, 2015 | 03:18 PM
fishEH's Avatar
This whole thread leaves me with the feeling you may have your terminology wrong.
Old Oct 13, 2015 | 03:25 PM
mcabrera3's Avatar
I'm here to learn. To my understanding we have cv axles that go from the bearing incide to the middle of the differential!
Old Oct 13, 2015 | 05:54 PM
ihscouts's Avatar
The axle shaft is what the CV attaches to and they're attached at the ends of both solid front axle shafts. They're under the rubber boot on both front wheels. It's what allows the front wheels to pivot while powered (rotated) by the front differential. When they wear they pop or click especially when under load (foot on the gas pedal is load). Check the rubber boots for tears/separation/water and dirt (mud) ingress and broken bands. Your CV's are worn and you actually said so without realizing it....... the U turn/when turning right or left. The only other thing you'd hear popping or clicking from is the front drive shaft and if it's bad you'll soon find out. It too can snap/crackle/pop under load but you'd feel a vibration while traveling in a straight line and that is the difference between them.
Download the "Rave" landroverresource.com and that way we'll all be on the same page and you'll learn about your Disco.
Old Oct 21, 2015 | 01:26 AM
MrValingo's Avatar
In the op's first post, I read "I haven't done any off road at all" and thought it was a strange thing to add if you actually hadn't. But I see in your other threads you have. Water gets all kinds of places and brings in dirt while taking away grease. If you want educated advice it's best to provide all the info so people aren't guessing in the wrong direction
javarover
Apr 4, 2007 01:24 AM
tailchaser0527
Mar 5, 2007 06:23 PM
ElMaestro
Aug 3, 2006 11:38 PM
toxico
Oct 20, 2005 02:15 PM
03se3
Freelander
May 24, 2005 12:36 PM
