Sponsored by: CARiD
Is this diode supposed to be here?
Old Aug 10, 2006 | 11:39 AM
alpinab7's Avatar
Default Is this diode supposed to be here?
On my 1993 RR LWB 4.2l there is a 5-6 inch wire coming from the negative side of the ignition coil that goes to ground and it has a small diode on the wire. I don't see it showing up on any wiring schematics. Is it supposed to be there? Does anyone else have it on theirs? This is not the resistor on the wire back to the ECU. I have a no start problem and am just wondering what this diode is doing here.
Old Aug 11, 2006 | 01:26 AM
Bait's Avatar
Default RE: Is this diode supposed to be here?
I think you are referring to the capacitor. It's a small cylinder meant to suppress noise. You can disconnect it and continue on with your diagnostics.
Old Aug 11, 2006 | 09:43 AM
alpinab7's Avatar
No. I should have ruled that out in my original post. The capacitor is there but on a different wire is a tiny diode about 1/10th the size of the capacitor. I'm wondering if it is factory or not. It was covered with hard rubber so before I peeled the rubber I didn't even know there was anything there.
Old Aug 11, 2006 | 10:05 AM
Landzu's Avatar
It maybe a fusible link, not like a normal (in looks) fuse but will blow to
stop a over load.
Old Aug 11, 2006 | 10:23 AM
alpinab7's Avatar
Well it's definately a diode. i WENT TO rADIO SHACK to buy a new one and they have them listed as "rectifier diodes". Same # on it.
Old Aug 12, 2006 | 12:03 AM
Bait's Avatar
No diodes are factory there. Is there a wire attached to it? May be some sort of alarm system.
Old Aug 13, 2006 | 01:14 PM
alpinab7's Avatar
The wire goes from the negative terminal of the coil to ground on the fender. It is about 6" long. Thats it, just a wire with a diode..........
Old Jul 29, 2022 | 07:51 AM
SteveD59's Avatar
Did this ever get resolved? We're trying to replace what appears to be the same device (ERR4019) which is quoted as a diode. I think it's a zener type to protect against back emf damage.
Old Nov 17, 2023 | 10:55 AM
danyjames_9's Avatar
Banned
landroverken
Dec 10, 2022 06:51 PM
nura78
Oct 18, 2022 09:57 AM
Micmac
Sep 16, 2020 11:06 AM
mx468
Aug 3, 2012 05:38 PM
alpinab7
Aug 10, 2006 11:40 AM
