Sponsored by: CARiD
View Poll Results: Disco 2 will not start with basic key
Can't start with basic key
0%
Alarm goes off when door is opened
0%
Voters: 0. You may not vote on this poll
Disco 2 won't start with basic key
Old Feb 23, 2013 | 07:27 PM
CRdisco2's Avatar
6th Gear
Default Disco 2 won't start with basic key
I have a 1999 disco 2 diesel. Car starts and runs fine with key with electronic components of the remote door opener. Other key does not have good electronic. Bad key opens door and powers up all dash functions including fuel pump but will not crank engine. Everything I have read says the basic key should start everything if the car was unlocked with the remote control. Both keys lock and unlock doors using the drivers door lock and manually unlocking door with key. Both keys power up everything but the bad key missing electronics will not crank starter. The one interesting thing is that when the drivers door is opened after unlocking the doors with the key the alarm sounds and can only be reset with the good key in the ignition. Anyone know what's going on. Car is in Costa Rica.
Old Feb 23, 2013 | 09:23 PM
Perhaps unlike the North American trucks yours may have a coil around the ignition that picks up the electronic parts inside the special key. See attached page from RAVE shop manual. Solution would be another expensive key, plus getting truck and key to accept each other, not 100% sure if you would need dealer / advanced shop programming on that.
One way to test for this is use the plain key in the ignition, and just hold other key close by to be "scanned".
Real problem if you left the good key back in the show-me state.
File Type: pdf
toad2
Jan 17, 2014 09:19 PM
CRdisco2
Feb 25, 2013 12:33 AM
flyingasics
May 22, 2007 01:03 PM
wvcox1
Jan 3, 2007 01:58 PM
newBrover
Oct 29, 2006 01:19 PM
