Sponsored by: CARiD
Disco 2004 slip sleeve
Old Sep 28, 2015 | 04:29 PM
GRB's Avatar
GRB
6th Gear
Default Disco 2004 slip sleeve
I have a 2004 disco. Does anyone know of a good mechanic in Colorado springs that can help as I believe I have a slip sleeve.
Old Sep 28, 2015 | 06:50 PM
GRB's Avatar
GRB
6th Gear
Any thoughts on swapping a range rover 2002 4.6 in a 2004 disco
Old Sep 29, 2015 | 09:44 AM
abran's Avatar
I did it on my dads 03'.
The thinking is that from 97-02 Land Rover was grading the blocks. Blocks marked with a red paint dab were the highest quality(thickest cylinder walls) and were used for the 4.6 motors. By 03/04 they were only making 4.6 motors with these blocks so they no longer used the grading system, hence all the 4.6 failures on the disco 2 models.
So,I think it's good idea. You need to swap the flywheel and all the the accessory brackets(I think the power steering pump is the only different accessory). Besides that it's plug and play. Do the head gaskets, timing chain, and oil pump service while the motor is out at a minimum.
Phototone
Apr 24, 2008 05:15 PM
hasallhisteeth
Feb 6, 2008 06:55 PM
beyondyonder
Jul 2, 2007 10:17 AM
mowthat
Mar 18, 2007 05:44 AM
dickensheets
Oct 6, 2006 02:53 AM
