Sponsored by: CARiD
View Poll Results: Disco 3 General problem
Battery
0%
User error
0%
Components failure
100.00%
Voters: 1. You may not vote on this poll
Disco 3 Transmission change not available
Old Jul 27, 2020 | 10:10 PM
Riaan Herholdt's Avatar
Default Disco 3 Transmission Range change not available
Hi ,
Recently purchased Disco. 2.7 Manual V6 diesel
Park brake was repaired before I got her.
park brake was not working and I followed a sequenced to “reprogram” which lead to my current problem.
When turning car on - HDC not available and park brake release failure .
this what I did .
1 turn car on and select low range
run through all the gears starting at Reverse , 123456. Turn off and on . Gear selection on the dash is back and park brake release is note is gone , but now the car is stuck in low range.
The message on the dash when turning on the ignition “ Transmisson stange change not available.
What have I done-
1. I have stripped and cleaned the selector button on Centre console. Seems this was opened before as screws where loose.
2. Removed and check battery terminals for corrosion- no problem their.
3 . Remove Ecu behind battery and check for corrosion . No problem their .
What is my next step ?
Can someone please assist?
amer_qureshi
Jul 10, 2024 02:03 PM
Nelanye Triana
Jan 15, 2018 02:46 PM
rmace1
Jan 16, 2012 08:27 PM
Canizales
Dec 14, 2011 05:26 PM
sloppyjoe
Nov 7, 2008 07:32 PM
