Sponsored by: CARiD
disco electric windows
Old Oct 14, 2007 | 01:17 PM
andrewvmurray's Avatar
Default disco electric windows
disco 1994 rear electric windows do they have a relay? if so where is it? font electric windows working fine.
Old Oct 16, 2007 | 04:47 AM
Pierre's Avatar
Default RE: disco electric windows
Probably underneath cubby box between the seats - should be two relays near the ECU for the windows.
But I'd check that the kidproof switch (between the rear window switches) was operating properly first.
You could then start to investigate the interior of the doors, but with both windowsnot operating, I'd bet on something a little simpler and most likely electrical.
HTH
Pete
Old Oct 16, 2007 | 08:44 AM
Might also be the body ECU that is failing.
Old Oct 16, 2007 | 10:21 AM
Landzu's Avatar
Look in the post about the rear windows not working there is a link
that will show you what you need.
Poggi
Aug 10, 2015 12:27 AM
OzarkRover
Jun 1, 2012 03:15 PM
silverfish
Sep 12, 2007 08:30 AM
silverfish
Jun 26, 2007 11:24 AM
uberrover
Jan 22, 2005 05:58 PM
