Sponsored by: CARiD
Disco I Warning lights
Old Jan 27, 2013 | 06:24 AM
Adam78's Avatar
Default Disco I Warning lights
Hey everyone, my 'new' disco has an amber warning light on the dash. It looks like a 4x4 light, but I dont have, and cannot find an online manual so I'm not sure what it means. I THINK the 4x4 is working. But not sure. Thanks guys!
Old Jan 27, 2013 | 08:28 AM
Links below to manuals (called the RAVE). You have the CDL shifter in the engaged position. It will most likely be stiff if seldom used. Not advised to drive on dry pavement for any distance that way, places extra strain on drive train. Made for soft surfaces (mud, sand, dirt, snow).
The RAVE has owner, shop, electical, overhauul, body repair, etc. Here are three pages from the owners to get you started.
File Type: pdf
Old Jan 27, 2013 | 08:55 AM
antichrist's Avatar
If you've been driving it much with the CDL locked the drive train may be too bound up to release back to unlocked. Backing up a short distance may be enough to free it. But you may need to back up on a loose surface or jack up one end to unbind it.
Old Jan 27, 2013 | 10:55 AM
Adam78's Avatar
ah ha! Thanks guys, come to think of it, the lever was VERY stiff to shift, but before purchasing the car there were no lights on. After i put it into CDL High the light came on and hasnt gone off (even after just going to 4Hi) i'll try the backing up thing and make sure its in 4Hi once I get plates on it. Thanks!
Old Jan 27, 2013 | 01:48 PM
Adam78's Avatar
No luck, I can physically put it into 4hi and 4cdl, but the light stays on. I'm not sure if there is a sensor that is busted under the truck or not? It's a mechanical linkage that goes to the transfer case, so if it goes it should work right? Also, I tried driving up and down the driveway in both, the steering feels heavier in CDL but i'm not sure bc the power steering is very finicky. Any suggestions?
Old Jan 27, 2013 | 03:26 PM
Adam78's Avatar
SUCCESS! After quite a bit of digging on google, someone said to open the pass side door, and just give it the beans when pulling. I Yanked back and forth pretty hard then threw it into 4Hi and WHAM! The light went off and the lever is easier to move now. I'm assuming the previous owner never touched the damn thing and just left it in 4Hi. As I will be doing until I can lube up the linkage. One problem down!
cipher982
Nov 9, 2019 11:22 AM
patriot1
Apr 22, 2008 03:13 PM
dave disco2
Aug 16, 2007 07:32 AM
97DiscoKid
Aug 12, 2007 12:11 AM
ptmelendez
May 12, 2006 08:06 PM
