Sponsored by: CARiD
DISCO II DRIVER DOOR LOCK
Old Jul 28, 2008 | 06:28 PM
ROSAS's Avatar
Default DISCO II DRIVER DOOR LOCK
HI
I'M NOT ABLE TO LOCK THE DOOR LOCK WITH THE DRIVER KEY ENTRY , IT IS ALSO NOT LOCKING AT ALL.
Old Jul 28, 2008 | 08:01 PM
WolfPack's Avatar
Default RE: DISCO II DRIVER DOOR LOCK
caps lock is not cruise control for cool
As for the lock issue...you probably lost the connecting rod from the cylinder to the lock. Does the RKE unlock the doors, just not the drivers door? Please elaborate so we can give you better advice..
Old Jul 29, 2008 | 02:32 PM
LrTECH's Avatar
most likely will need a drivers door latch. It pretty involved to replace it.
Old Jul 29, 2008 | 04:50 PM
WolfPack's Avatar
Cost me just shy of $1000 to replace mine.
Old Jul 29, 2008 | 08:55 PM
ROSAS's Avatar
i've had my discovery II for three years and try to fix what i can, but i also do not want to make it worse.
when you turn the key in the door handle it does not click to unlock or lock it turns freely.
the door lock button inside still works it locks and um-locks all the doors
at this point i do not lock any of them
Old Jul 29, 2008 | 11:42 PM
WolfPack's Avatar
That's exactly what mine did. Mine led up to getting accidentally super-locked, and I was completely screwed because the key cylinder did not work. No EKA access...couldn't even get the door popped open because then the alarm would go off and since my key was not sync'd I'd be double screwed.
korperlich
Jan 8, 2011 12:41 PM
sharbel
Nov 2, 2006 11:01 AM
99Landrover
Mar 13, 2006 11:37 PM
Benhamtroll
Jul 18, 2005 11:32 AM
