Sponsored by: CARiD
Disco II stuck in park
Old Jan 18, 2009 | 03:40 PM
stanton1275's Avatar
Default Disco II stuck in park
I went out to get in my 2000 Discovery yesterday morning, and it would not come out of park. It had been running perfectly normal before then. I have looked around under the it, and nothing looks out of the ordinary. We have been experiencing unusually cold weather recently, but I don't expect that would cause it. Any ideas what could have caused this?
Old Jan 18, 2009 | 04:29 PM
philiplarson's Avatar
Default RE: Disco II stuck in park
Same problem here about two months ago. Check you brake lights, if they are not working, you will need to repalce the brake light switch. I bought one from the dealer for $13.00. Real easy to replace about 5 mintues tops.
Phil
Old Jan 18, 2009 | 05:33 PM
If you PM me your tele number, I will walk you thru a quick fix till you get a new brake switch.
Old Jan 18, 2009 | 06:26 PM
Thanks, it looks like I have the same problem you did. Where is the brake light switch located?
Old Jan 18, 2009 | 06:52 PM
Look above the brake petal. It has a connector with three wires attached to it. It will turn a quarter of a turn.
In the mean time, you can pry up the cover that is around your shifter. Use a flat tip screw driver and remove this cover. You will see a locking pin on the shifter, this keeps it in park. Use a pen or phillips screw driver to depress the pin.
Phil
amer_qureshi
Jul 10, 2024 02:03 PM
Roywilliams14
May 17, 2014 01:27 PM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
TipStylez
Jun 27, 2006 10:10 AM
