Sponsored by: CARiD
Disco rear door
Old Oct 17, 2007 | 03:56 AM
christaci's Avatar
5th Gear
Default Disco rear door
I have a disco 97. Every time I go over a bumpmy rear doorrattles as if it is half closed.The hinges look solid to meeven when I try to physically move the door up and down. With the spare mounted on the back I guess there is a lot of weight to bear. Is this a regular disco problem, do the hingesbecome lazy and out of adjustment or is it a problem specific to my car. Can anyone help.
Thanks
Chris
Old Oct 17, 2007 | 06:44 AM
Landzu's Avatar
Default RE: Disco rear door
Mine is the same but I was thinking it was my two rear seats.
Old Oct 17, 2007 | 08:01 AM
Yes, with time both the hinges and the latch assembly start showing wear. Lube the door check under the door at the hinges, and inspect the latch, probably needs to be clean, lubed and adjusted.
jigray3
Jul 30, 2019 07:52 PM
Jedelmann
Feb 18, 2015 07:30 PM
bcolins
Jun 22, 2013 08:55 PM
CandiMan
Aug 24, 2008 10:35 PM
