Sponsored by: CARiD
Disco series II subwoofer wiring question
Old Jun 27, 2008 | 03:27 PM
harp's Avatar
3rd Gear
Default Disco series II subwoofer wiring question
I wasnt sure where to post this. I apologize.
I need a wiring schematic as I replaced the two 6 1/2 inch rear woofers with a single10 inch subwoofer in the back. I need to bridge the 4 wires (4 different color patterns on them)from the smallerwoofersto the +/- of the new speaker,and I can't figure out the combination to fix the phasing issue.
Any help would be greatly appreciated!
Thanks!
Old Mar 14, 2012 | 11:46 AM
RedBusRover's Avatar
Default Did you find an answer?
Hi,
This is a bit of long shot, but did you get an answer and morover do you still have the detail on what wires do what on the sub?
I've recently bought a D2 GS which doesn't have the sub as it was a low line audio model, but I've picked up a cheap second hand sub enclosure that has the amp fitted across the back, but sadly then found no wiring and plug hanging in wait when I pulled off the rear door card.
My intention is to replace the speakers, take the sub output from my replacement Alpine Head unit and run a single pair to the amp input.
I've opened the amp unit and can see 2 pins marked 12v, 1 marked EN, 1 Sig, 1 S0v and 1 P0v. There's 2 amps inside, one driving one speaker connection, and the 2nd the other. Just need to find out which is + or - for 12v, and which one is the signal pair.
Any ideas? Even if you can tell me the positions and colours entering the 6 pin plug would help.
Hoping you have a long memory!!
Regards
Shaun
Old Mar 14, 2012 | 02:37 PM
RedBusRover - the complete set of factory wiring manuals is part of the RAVE download. It contains color circuit diagrams, and in the electrical library the pictures in color and pin outs of every connector. See link below. Same thing the dealer uses.
aguison
Oct 9, 2012 07:57 AM
kjmass1
Aug 18, 2010 08:19 PM
mellyagaunce
Apr 2, 2009 10:13 PM
harp
Jun 27, 2008 07:52 PM
Core_Shot
Feb 1, 2008 12:31 AM
