Sponsored by: CARiD
Disco tick question
Old Oct 10, 2016 | 05:55 PM
Ursula's Avatar
Default Disco tick question
Like some of you I have the wonderful disco tap once she warns up to temperature.
I have read a good amount of posts on this and other sites about this issue and have been researching for a little while now.
The only difference with my ticking that I notice is at times it goes away.
Its mostly there once she's hot but there are times when I would rav it up hard and it would go away or I would hit a weird angle and it would go away.
There have also been plenty of times that I would get to my destination and I would hear it but after I get back from say the store and I fire her back up the tick is there but will slowly start quieting down.
So I learned from my previous recent post there might be other solutions to problems then to just start ripping things out and replacing them.
So the first cheap thing I wanted to try and get your input in is a thicker oil...
I don't know what the truck ran before I got her but I switched it out to Rottela 10-40
I understand it could be the liners or the lifter and so on. But any suggestions or recommendations for me to try a thicker oil that will not over work the engine would be great. As I think this would a good place to start.
I am planning on testing my oil pressure this week and will have a better idea on what the pump is downing.
Not looking to start a oil war- just suggestions on a thicker thats safe to use oil.
thanks!
Old Oct 10, 2016 | 07:43 PM
number9's Avatar
thanks!
I've used 20w-50 down to zero degrees with no adverse affects in both hyd lifter and OHC engines.
Old Oct 11, 2016 | 04:18 PM
Ursula's Avatar
Thanks for that info- I think I am gonna try the 15-40 blend of Rottela before I change brands again. I don't see a 20-50 blend in that Brand.
However is there much of a difference from a 10-40 to a 15-40?
Unless any other suggestions I will switch it out tonight and I'll report back on the tick.
Old Oct 11, 2016 | 10:15 PM
mollusc's Avatar
In your first post you say you're running Rotella 10W-40. Then you say you're going to try the 15W-40.
I don't think there's a 10W-40 in the Rotella line, so perhaps you're actually using the 10W-30 which is a synthetic blend. If you switch to the 15W-40, that's straight dino so it may not play nicely with the synth.
Old Oct 18, 2016 | 01:09 AM
Ursula's Avatar
Busy week.... finally getting back to my disco...
Rotella makes a 10w-40. Its a synthetic oil its a T5 or something.
I am running 10-40 in my disco now not 5-40.
So I am gonna switch it out this week with a 15w-40 but again wondering if going from a 10-40 to a 15w-40 is that much of a difference? If not then I am thinking 20w-40.
thoughts? Thanks!
Old Oct 18, 2016 | 06:47 AM
mollusc's Avatar
Regardless of the effect of any change in viscosity, you're complicating things by potentially mixing synthetic and dino oils.
xengineguy
Nov 12, 2015 12:23 PM
XCELLER8
Sep 19, 2009 03:27 PM
zracin
Mar 7, 2008 01:17 PM
Kraftyz51
Aug 19, 2007 03:58 PM
97XD
Feb 2, 2007 07:46 PM
