discovery 2 imobliser and alarm problem
hi i have a disco2 and the alarm and immobiler kee fob will not open it or close it and to add to my bother the door lock seems to b broke so i cant open with kee ..
is their any way to bypass the immobilesr and alarm can i remove it ?..
i only use it for hunting ans general a second car.
their must b sum way to bypass the 2 problem issues
No, call a locksmith, they might get in. if not you have to break the rear window to open the door. That would be the corner window. Its the cheapest. Then you need to buy a new lock or get it rebuilt by the locksmith. You just pull the handle and give it to them to rebuild. You will have two keys but one lock.
unlock the vehicle and cycle the key a few times and leave it in the ignition. Sometimes those will start it just needs to see a signal from the lock. or you could lock the vehicle, disconnect the battery hook it back up and then unlock the door to disarm it.
oh and most importantly push the door latch in so the vehicle thinks the door is shut.
3 and a half hour drive for me to take it on a trailer
u can also wedg top of doo out and open with a bit of wire ,,
hear is a small up date guys i still have not got a running jeep arrrrr.
left it in a 4x4 garage he is not having much luck kee working fine bcu ecu working but still not go car will not recive kee fob and will not turn over ..
so any advice at this stage would help .
new reciver fitted as well sum one must of had this problem b4 i cant b the only one in the world with this problem ..
can i bypass imobiliser ??
