Sponsored by: CARiD
Discovery 2 Viscous Fan Coupling
Old Nov 1, 2013 | 05:43 PM
OffroadFrance's Avatar
Default Discovery 2 Viscous Fan Coupling
Hi
Does anyone know how much silicon oil and what grade is needed to refurbish the viscous fan coupling on the D2. I had thought it was 250ml's of 10,000 CST but that from distant memory.
Old Nov 1, 2013 | 05:59 PM
dusty1's Avatar
didn't even know you could do such a thing. I thought it was a disposable part....but I do have a disclaimer
vvv
vv
v
Old Nov 3, 2013 | 06:56 AM
If it has leaked out enough fluid to need refill, it will most likely leak out new fluid quickly as seal is not going to repair itself. Here in the States the fan clutch from a 2000 Chevy Express van, 4.3 liter, without A/C, is the same size (6 inch), and rotation, and thread. You just have to use different fan to clutch bolts and enlarge hole slightly.
In a pinch, hydraulic jack oil, etc. Or drill thru clutch with two screws (it becomes a 100% coupling) and you can make it home from the desert. If just driving on highway, without stopping for drive thrus, just take fan off, it is not needed above 50 mph.
Old Nov 3, 2013 | 08:24 AM
Buy a new clutch, refilling is not an option.
Old Nov 4, 2013 | 12:07 PM
Thanks you guys,
I'll test it again both hot and cold and see what it performs like. It's not overheating at present but is slightly higher than normal over the past two months on the gauge (LR 'carp' gauge) which made me look at the viscous fan unit. I might also fit auxilary digital temperature and oil pressure gauges to be on the safe side now the truck is getting old with 120K miles on it.
BG Simons
Mar 9, 2015 12:19 PM
0304Disco
Jun 15, 2012 02:00 PM
sanmigmike
Feb 21, 2011 05:28 PM
raid13
May 26, 2007 01:23 PM
ScottM
Dec 26, 2006 07:14 PM
