Sponsored by: CARiD
Discovery Gear Reduction
Old Apr 22, 2012 | 11:34 PM
XDdisco's Avatar
Default Discovery Gear Reduction
I am currently running 285/75/16 on my 1997 disco 1 XD. I am going to go to 315/75/16s, and am looking for some new gears, (will be upgrading Drive lines, Housings to ARB or Ascroft air lockers, axle shafts to hd etc...) and was wondering what people thought. I would like to know what ratio of crown gear and pinion people would suggest with this size tire. I was thinking somewhere in the size of 4.7ish to 4.43. I would like to know the mph with rpm if possible in high gear. Any help would be great. I also have found some land rover gears that I am interested in but not sure if they will fit a disco... anyone have any cross reference numbers? Their part number is not an American number and I can not figure out how to cross reference the numbers. They are 4.7 gears, and the parts number is RTC 2990. I think it is a UK number, but not sure. Thanks!!!
Old Apr 23, 2012 | 05:24 AM
see Tire Size Calculator - Compare Tire Sizes
seems like you would increase circumference about 5%. So add 5 mph to speedo readings to be safe and ticket free. You'll still have enough rpm to exceed the legal limit and the rational maximum for a 4500 top heavy aluminum and steel tea kettle on wheels.
File Type: pdf
Old Apr 24, 2012 | 08:34 AM
XDdisco's Avatar
Thanks Savannah Buzz. Does any know how to cross reference uk part numbers with U.S. part numbers? The dealership said they could not do it. Specifically I am looking to see if part number RTC 2990 would fit a 1997 disco. I am including the link on ebay that has the gear set. Thanks agian....
LAND ROVER CROWN WHEEL PINION GEAR RTC 2990 2365 1950-84 LANDROVER AXLE 4.7ratio | eBay
bcolins
Jun 10, 2011 11:36 PM
jalbright2000
Dec 30, 2010 07:05 PM
Lee1140
Dec 1, 2009 10:17 AM
ljdiscovery
Jun 10, 2009 09:03 AM
