Discovery II shakes above 70 mph
Gentlemen,
I am new to this forum and I have been searching for an answer to my truck shaking for a few weeks now. Since it began shaking I have had the tires balanced, replaced the u-joints (I found a broken one). Replaced the front propshaft completely. Finally Yesterday I replaced the transfer case output bearing. Truck still shakes above 70mph. When I pull the front shaft out the shaking goes away. I can feel the shaking with the front shaft in around 40mph but it smooths out then at 70-80 is shake a lot. What are the chances of it being a bad balance on the new shaft? I went cheap and bought a masterpro from Orielly auto parts. Also to note when I changed the transfer case fluid there was what I thought an abnormal amount of metal shavings on the plug. Does anyone know of internal issues from the transfer case I should start looking at?
Gentlemen,
vapro10s
Dec 5, 2010 10:20 AM
Kinversand
Jun 30, 2008 08:31 AM
ghinesley
Aug 6, 2007 01:48 PM
