Sponsored by: CARiD
Discovery popping back through intake
Old Jul 13, 2012 | 09:11 PM
Stan Pittman's Avatar
Default Discovery popping back through intake
I have a 98 Discovery in the shop that will barely run. When you get it started it pops back through the intake like an engine would do with a rounded cam lobe or stopped up exhaust. I removed the valve covers and all rockers are moving and I disconnected the exhaust down pipes and no difference. I have codes P0307 P0308 P1340. Could the camshaft position sensor cause this or maybe camshaft jumped timing or am I missing something simple.
Old Jul 13, 2012 | 11:56 PM
01bluedisco's Avatar
Have you check the engine compression? That would narrow it down.
Old Jul 14, 2012 | 10:03 AM
Yes the compression is good
Old Jul 14, 2012 | 10:28 AM
jafir's Avatar
Worn cam lobe is not unheard of.
Old Jul 14, 2012 | 05:13 PM
How many miles are on it?
Check the timing, I'm betting the timing chain jumped a tooth or is stretched.
CUpgt
Oct 1, 2013 11:52 AM
meltdowndave
Dec 29, 2009 01:54 PM
96SILVERDISCO
Jan 10, 2009 07:22 AM
birdhunter61
Oct 6, 2008 09:04 AM
Savannah
Jan 24, 2008 03:44 PM
