Sponsored by: CARiD
Discovery Sport “gearbox fault”
Old Feb 1, 2026 | 11:00 PM
Cummerbund's Avatar
Default Discovery Sport “gearbox fault”
I’m trying to figure out if this is a known issue or if anyone else has experienced something similar.
2023 Discovery Sport, ~45k miles, still under warranty. Over the past year, I’ve had intermittent electrical issues that all seem to trace back to auto start-stop, especially in cold weather.
Symptoms:
– Auto start-stop engages at a stop (stoplight, stop sign, etc)
– On restart, vehicle throws a gearbox fault and locks up
– Requires turning the car off and back on
– Immediately after restart, I’ve also seen a charging system fault
– Happens most often after cold soak (~35°F), short drive (10–15 min), then stop
– Clears on restart and drives normally afterward
Dealer has been unable to replicate so far. Battery was replaced previously for “negative battery,” but the fault has returned.
This is becoming a safety concern since it’s happened in traffic. Curious if anyone has seen:
– Start-stop causing voltage instability
– Alternator/BMS issues in cold weather
– Known Discovery Sport electrical faults like this
Sking
Discovery Sport
Sep 1, 2024 06:11 AM
jm96666
Jan 28, 2023 03:28 AM
Pierie
Aug 7, 2022 10:27 AM
Disco41989
Sep 12, 2019 03:12 AM
boldguard79
Apr 18, 2018 02:20 PM
