Dissapointing head gasket job
Old 07-07-2011, 08:06 AM
haleyrover's Avatar
Unhappy Dissapointing head gasket job
Well, I thought I was doing a good job on my first attempt at a HG replacement. I followed rave and some posts to the letter. I went to crank it up last night and it wouldn't turn over. Hoping it's something simple. Any suggestions where I should troubleshoot first before tearing it back down? Plenty of battery, makes a whine, just no combustion.
'04 Disco II
74k
Old 07-07-2011, 09:51 AM
XCELLER8's Avatar
check your battery connections as well as the ground to the engine and frame.
Old 07-07-2011, 09:55 AM
drowssap's Avatar
sorry to here that, i know how disapointing that could be.
lets start with the basics
"wont turn over" it does not crank? or does it crank and just wont start?
"makes a whine" what is make it whine the engine or the starter?
"just no combustion" does it have compression?
Old 07-07-2011, 10:13 AM
haleyrover's Avatar
Thanks, I was pretty crushed. It cranks just wont start. The whine I believe is the starter. I was alone so didn't get the opportunity to get near the engine while I tried to start it. Basically, the belt moves, the starter whines, but nothing else.
'04 Disco II
74k
Old 07-07-2011, 10:19 AM
Hit the reset button for the inerita switch on the passenger fire wall near the heater hoses.
Old 07-07-2011, 10:21 AM
drowssap's Avatar
well if your belts are moving then it is cranking over.
Cranking fast, slow or normal?
Old 07-07-2011, 10:38 AM
So, if resetting the switch doesn't work, then check and make sure the crank sensor is not damaged
Old 07-07-2011, 10:44 AM
haleyrover's Avatar
Thanks, Guys. I'll try all that tonight!
04 Disco II
74k
Old 07-07-2011, 04:51 PM
haleyrover's Avatar
Well. Good news is that worked. Bad news is .... it started chugging like a freight train so I shut it down. Not sure what to do next. Going to get beer.
04 Disco II
74k
Old 07-07-2011, 04:59 PM
wheelgarage's Avatar
As mentioned....check the crank sensor...
Quick Reply: Dissapointing head gasket job
