Sponsored by: CARiD
Dll won't move
Old Jan 21, 2013 | 06:48 PM
Merritt87's Avatar
Default Dll won't move Pls help!!
I have a 01 land rover discovery. It was driving fine and just stopped driving as if I had no tran fluid The MS and D light flashing and won't move either way/ limp mode. I have 3 codes P1884 P0103 P0722.
Old Jan 21, 2013 | 09:50 PM
Have you looked under the truck?
How many miles on it?
Old Jan 22, 2013 | 12:16 AM
0722 - torque converter slipping
0103 - mass airflow sensor has a signal that is higher than speed range would expect
1884 - can't read with ordinary scanner, need dealer level unit to get the second part of the code (from tranny ECU)
I'd say check fluid level, and a fluid and filter change might be in your future. The lack of previous slipping is a good sign.
Old Jan 22, 2013 | 12:32 AM
Merritt87's Avatar
I've changed the fluid and filter still nothing..
Old Jan 22, 2013 | 12:36 AM
Merritt87's Avatar
[QUOTE=Spike555;372117]Have you looked under the truck?
How many miles on it?[/QUOTE
12k on it.. Yes I've looked under it I have no movement..
Old Jan 22, 2013 | 12:55 AM
Engine compartment fuse 12, fuse link 8 (fuse that bolts in), under dash fuse 24 and fuse 25 should be checked. Cable connector from tranny to tranny ECU should be checked, also XYZ conector. See attached.
File Type: pdf
Old Jan 22, 2013 | 01:04 AM
Merritt87's Avatar
Ill check them ASAP and get back to you. Thanks a lot for the response
Old Jan 22, 2013 | 01:09 AM
It's 2 AM here.... you need to open the attachment and see the picture from the RAVE of the connectors. Is this the year without a CDL lever, but has a spud on the transfer case for it? That you turn with a 10mm wrench? I guess if it somehow got to "N" then no forward or back.
Old Jan 22, 2013 | 01:22 AM
Merritt87's Avatar
I'm not to sure about the spud. Checked the fuses they look good. Ill get under and check the xyz switch in the morning and let you know. I've messed with it b4 took it off and checked it out it looked in good condition I've read about a hose above it
Old Jan 22, 2013 | 01:26 AM
Merritt87's Avatar
Originally Posted by Merritt87
I'm not to sure about the spud. Checked the fuses they look good. Ill get under and check the xyz switch in the morning and let you know. I've messed with it b4 took it off and checked it out it looked in good condition I've read about a house above it
Hose*
