Sponsored by: CARiD
Do I need to clear error codes or will they...
Old Oct 14, 2014 | 03:39 PM
JoeLena's Avatar
Default Do I need to clear error codes or will they...
Resolve themselves? Didn't know another way to phrase it.
Have an '04 Discovery that has been throwing somes codes and have not been able to pass inspection. New MAF seemed to fix the lean codes but I still have a PO441 showing.
Question is: Will the CEL go out after it is resolved, or must I clear the codes with the UltraGauge manually? I would prefer not to clear them if I do not have to since I would need to go another 100 miles or so to cycle the system before getting it inspected again.
Anyone know about this?
Old Oct 17, 2014 | 08:07 AM
abran's Avatar
It is my understanding that you need to clear the codes. Hate to make you paranoid... But here I go- I had an 03' that had to be driven over 2000 miles before the evaporative readiness monitor was ready. My current 04' took just over 600 miles.
Good luck.
Old Oct 17, 2014 | 08:20 AM
JoeLena's Avatar
That would be really, really bad.
Old Oct 17, 2014 | 08:54 AM
dusty1's Avatar
I always clear codes.
Active fault will soon come back, but a system not ready or pending can take a bit to straighten itself out
Old Oct 17, 2014 | 09:07 AM
jafir's Avatar
MOST codes will reset the light themselves if the problem goes away, after about 3 cold starts. The code will still be stored on the computer, but the light will be off. I'm not sure how emissions checks work because we don't have them here, but I'm guessing they hook up even if the light is off to check for the readiness, in that case they may notice the old codes. but maybe they will see they aren't current anymore and not cause a stink. I personally wouldn't want to risk it.
Old Oct 17, 2014 | 10:38 AM
drowssap's Avatar
500 or so miles on mine before it would pass. state emission. if you do have emission testing they usually have a set mileage amount where they consider them clear.
they wouldnt want you waiting in line with an OBII scanner clearing codes before you enter the bay for inspection
Old Oct 20, 2014 | 06:16 AM
JoeLena's Avatar
Good luck.
So how did you know that it took so many miles? I have not been able to figure out how many miles are in a cycle for me. Sometimes it seems like they came back after 75 or so miles, other times 150 miles.
Guy at the testing site said it just needed to be a cycle and the light off, so codes on the computer.
Old Oct 20, 2014 | 08:28 AM
drowssap's Avatar
every state is different
Old Oct 20, 2014 | 08:39 AM
abran's Avatar
I bought an ultragauge that shows the readiness monitors. The evaporative is always the last to be ready. Harbor freights little red OBD2 CAN reader shows it as well.
kevlor80
Mar 2, 2017 10:37 PM
pixel
May 13, 2011 07:24 PM
rovernbama
May 15, 2006 03:03 PM
