Sponsored by: CARiD
does a 1995 discovery 1 3.9 liter have crank shaft sensor???
Old Dec 9, 2007 | 05:44 PM
bbeeff's Avatar
Default does a 1995 discovery 1 3.9 liter have crank shaft sensor???
does a 1995 discovery one with 3.9 have a crankshaft sensor?? if so where is it located??? i have work shop manual and no luck!!! thanks
Old Dec 10, 2007 | 03:07 PM
Savannah's Avatar
Default RE: does a 1995 discovery 1 3.9 liter have crank shaft sensor???
Hi bbeeff.
The 3.9 has no crankshaft sensor.Check for 12V supply on starter solonoid wire with key turned into start position.If there is no 12V,problem is with spider on top of your heaterbox.
Regards
Marius
Old Dec 11, 2007 | 12:28 PM
dcox's Avatar
No crank sensor, it uses a pickup coil in the distributor for the signal.
HighOnRover
Mar 7, 2014 05:13 PM
north_nm_rover
May 6, 2013 05:43 AM
Travelor
Sep 18, 2012 12:15 AM
houchenk
Jul 6, 2011 08:35 AM
kevlor80
Dec 2, 2010 06:51 PM
