2004 Discovery Crank Shaft Sensor
Old Jul 5, 2011 | 07:53 AM
houchenk's Avatar
Default 2004 Discovery Crank Shaft Sensor
I recently changed my crankshaft sensor after the original went bad. While trying to plug in the new part I pushed the female end of the plug above the bell housing. Has this happened to anyone before and is there and easy way to remove something other than the trans to get to it? Thanks for your help.
Old Jul 5, 2011 | 08:38 PM
I have no idea but I will give you a bump.
Part of the crank sensor fell inside the bell housing?
There is a inspection plate at the bottom, remove it, maybe the part is laying down there.
Old Jul 5, 2011 | 11:10 PM
thospb's Avatar
I believe he is talking about how the harnesses orginate behind the motor and he accidentally pushed the plug up out of reach.
Personally, I would try a length of coat-hanger to fish it out.
Good luck, keep us posted.
Old Jul 6, 2011 | 08:35 AM
jayman's Avatar
Can you see it if you shine a light up there?
HighOnRover
Mar 7, 2014 05:13 PM
Travelor
Sep 18, 2012 12:15 AM
cgeschwell
Feb 23, 2011 01:01 PM
stupid
Nov 23, 2008 01:17 PM
bbeeff
Dec 11, 2007 12:28 PM
