doors won't unlock
The only door I can unlock on2002 Discovery II is the front driver manually with the key. None of the other doors will open. They won't unlock/open with remote orinterior switch or If I use the door handle to open the door. Does anyone know how I can unlock the doors and what is going on with the lock/unlock?
I checked the fuse. It is fine. I started having this problem several months ago. At first the key wouldn't unlock but I could still pull the handle on theinside to open the doors. Then one day I couldn't even open the doors from the inside.
I have done some reading on here. Do you think it is the lock actuator? If so, do I have to replace the actuator on all four doors or just the front driver door? I have recently had my truck in to fix my window. Could they have broken something while in there?
I appreciate your help!
Ok, I will check to see if there is power to any of the lock actuators when I hit the dash lock switch.
This will take some time because I will need help checking this out. I may not check back until early January because I don't think I will have anyone who can help me before then.
I'll update then.... thanks for your help so far.
