Sponsored by: CARiD
Drive with suspension lowered/ noisey lifters
Old Nov 2, 2009 | 10:25 PM
colin2496's Avatar
Default Drive with suspension lowered/ noisey lifters
Hi people,
I have a 2003 HSE7 and firstly would like to know can I manoeuvre into my garage with the suspension lowered?
Also my engine has done 120,000 and sounds a little rattlely this is worse when cold. Are the lifters adjustable or hydraulic and am I just listening to fair wear and tear?
Should I dare have the local LR dealer listen to her??
Regards
Colin
Old Nov 3, 2009 | 09:50 AM
Never go to the dealre unless you want to get screwed.
Do you have a lift or roof rack on that is keeping you from going into the garage, and if so, how many inches does it need to drop?
How often do you change your oil, has you oil pressure light been staying own?
Old Nov 3, 2009 | 05:38 PM
colin2496's Avatar
only need to drop one inch and i have no roof rack et. The oil was changed 4000miles ago and I was planning on having it serviced and having winter oil put in. The vehicle has full landrover history and carfax proof. PS oil light goes out straight away after starting. Also engine noise is worse under load, but not really excessively noisy in that I do not feel like is about to explode, I recently pulled a 4000lbs trailer 1600miles with no real problems other than using a quart of oil.
Old Nov 4, 2009 | 05:32 PM
conrudsqui's Avatar
wamly welcome
Sure all pro gamer are most welcome... if you can reach out to them it would be great!! Thanks a lot
Old Nov 5, 2009 | 09:05 PM
colin2496's Avatar
Any body got more help than that??
Aulmeck
Feb 4, 2022 05:18 PM
colin2496
Nov 27, 2009 05:00 PM
Suede
May 16, 2009 05:32 PM
Spike555
Jan 12, 2009 10:49 AM
