Sponsored by: CARiD
driveshaft front double cardon joint
Old Oct 15, 2010 | 05:38 PM
asikuy's Avatar
Default driveshaft front double cardon joint
my frontdrive shaft failed today, and the double cardon joint was broken. Searching this website I now see, I could have saved myself the headache by doing some maintenance.
My big Q is, is it possible to just buy the double cardon joint? or is there no choice but the buy the whole shaft?
Thank you.
Old Oct 15, 2010 | 07:36 PM
antichrist's Avatar
I'm not aware of anyone who sells the DC unit. You could probably find one new, but that would cost as much as a used propshaft probably. I'd just get a used propshaft (don't pay over $100) and rebuild it before installing.
Or get a GBR or TW.
Old Oct 15, 2010 | 07:40 PM
Where are you located, are you at all mechanical so you can rebuild the replace so this doesn't happen again?
Old Oct 16, 2010 | 11:06 AM
asikuy's Avatar
I live in Sanford, FL.
Antichrist, what is GBR / TW, and where an I get one?
My mechanic is a good friend, he will rebuild it. Right now, LandRover sells me an OEM for $575, BritishAtlantic $399 for a driveshaft...
Looking at junkyard to get one. Is a driveshaft from other model car be used as long as the length is the same?
Old Oct 16, 2010 | 03:48 PM
SDinDS's Avatar
Want mine? Pay for shipping and it's yours
Previous owner said he replaced it last year but with an OEM one. I didn't have any problems with it and it looks in great shape. I just didn't want to chance it so I bought one from Drive Shaft Power in Lake Worth, FL. You can check out DSP's website and call them. They charged $311 including shipping, 2 year warranty, fully greased and ready to install. Or if you want a good shaft to rebuild, let me know.....
Eric
Old Oct 16, 2010 | 04:46 PM
asikuy's Avatar
Eric,
PM me your number, sure, I'll buy it. I just need this car to run for about 6 more months until it gets replaced. long story made short, been unemployed since June, soon back to work, but needed for my daughter to drive to college and back home..
I will PM you my phone #.
Old Oct 17, 2010 | 10:30 AM
asikuy's Avatar
Eric,
Here is my email address: asikuy@earthlink.net
you can send me your phone number and I'll call you later today.
Old Oct 19, 2010 | 12:12 AM
fujian90's Avatar
Default Double Cardon front drive shaft joint
At an early stage in the evolution of the high-speed diesel a variable timing device was introduced in the pump drive coupling, taking the form of a helically splined coupling by means of which the angular relation between driving and driven shafts could
Hapakid88
May 22, 2023 06:04 PM
CANAMDiscovery
Dec 19, 2012 09:40 AM
clemson rover
Jun 26, 2009 01:13 PM
kfx4001442
Jan 24, 2009 05:32 PM
ajh
Oct 16, 2007 10:11 PM
