Sponsored by: CARiD
EAS Plumbing Upgrade?
Old Nov 1, 2012 | 02:44 PM
Cottrell's Avatar
Default EAS Plumbing Upgrade?
I have noticed I cant find anything online referencing a switch of plumbing on the EAS system. First does anyone think it is possible and second would anyone else want this? Basically I thought it would be cool to replace the high pressure plastic hoses with braided line, and instead of having brass grommets to hold the hoses in convert the connections to screw on washer systems like how fluid lines connect. This would cut down on cost and time to fix. Any input appreciated.
Old Nov 1, 2012 | 03:12 PM
Rovin4life's Avatar
it does nothing for it. the collared fittings on newer ones are still plastic. Braided does nothing.
Old Nov 2, 2012 | 01:43 PM
Cottrell's Avatar
I didn't mean it necessarily had to be braided hose, but as far as doing nothing for it. The collard fittings must be so much easier to repair yourself no? Thats mostly why I would want it.
Old Nov 3, 2012 | 10:29 AM
Rovin4life's Avatar
Actually its more difficult with the newer style. The older style you just clip the hose with the hose cutter. A pair of cutters will oblong the end and not work. You just need new 6mm orings and you are set.
Old Nov 4, 2012 | 04:57 PM
Cottrell's Avatar
When you say a pair of cutters making the hose oblong do you mean pliers. I ordered the O'ring kit I don't want to mess up the hose tho. Thanks
Old Nov 4, 2012 | 05:49 PM
Rovin4life's Avatar
Dykes, don't use dykes. Use plastic or rubber hose cutter if you can find one. If not use a razor blade.
Old Nov 4, 2012 | 06:15 PM
Bkreutz's Avatar
You can get plastic hose cutters at the big box stores, look in the irrigation plumbing section (they use little plastic hoses about the same size as the hoses on a Rover)
Old Nov 6, 2012 | 02:12 PM
Cottrell's Avatar
Thanks guys, really appreciate all this input, so I figured while doing the O'rings I would just do the compressor all in one whack. If you have any advice on that it is also welcome. I bought a compressor rebuild kit from the netherlands that claims to be second gen. They use different materials for the compressor seal and cylinder anyone have any experience with them. They are red in color. Range Rover P38 EAS Seal Liner Set New 2nd Gen | eBay
beemin3
May 4, 2015 04:14 PM
mmaesner
Apr 8, 2015 02:55 PM
simjack
Oct 12, 2008 10:24 AM
VB_Rover
Jun 23, 2005 02:29 AM
jstraw
Jun 1, 2005 12:29 AM
