Sponsored by: CARiD
ECU ground fault 76 ?
Old Sep 18, 2013 | 10:56 AM
aftermath431's Avatar
Default ECU ground fault 76 ?
I have a 2000 land rover disco II. 4.0 engine. I went to a mechanic in town and he put a scanner on for my 3 amigo light and said the front passage side & drivers side rear wheel speed senor where bad. so I'm going to have those replaced. but he also had a engine code i think - code that he could not look up online. the code is ECU ground fault 76. Can someone please tell me what this is so I can try to fix it myself?
Old Sep 18, 2013 | 11:33 AM
did not see that number, but there is a 1776, page for that attached. The computer modules (there are several) talk among themselves on a data bus, if cable is skinned, shorted, open, strange things can happen.
File Type: pdf
Old Sep 18, 2013 | 01:01 PM
Default where would I find the code so I can get to the problem?
I really don't no anything about codes i'm use to working on a 65 Impala.
can you tell me how I can find out what this code is for? I have the manual for Land Rover but I just downloaded it yesterday and haven't gotten a chance to go through it.
Old Sep 18, 2013 | 09:07 PM
You can stoop by most auto parts stores, and they will read the codes for free. Write down the numbers. Post back.
aftermath431
Jan 8, 2015 11:40 AM
06Range
May 8, 2013 09:01 PM
RROJ
Jul 24, 2011 07:59 AM
kcirtap
Sep 26, 2007 09:39 AM
