Sponsored by: CARiD
Electrical issue with my discovery
Old Feb 18, 2008 | 06:10 PM
jairocol's Avatar
Default Electrical issue with my discovery
Hi , I am havingelectrical problems with my discovery 96 where my battery is dying while driving because my alternador is not working correctly. Replaced Battery few times with a battery from Costco (100 monts warranty) and I also replaced Alternator ( when I took this one to autozone they say the diodes were bad), replaced battery and alternator and issue still there. ( only 12 volts when measure voltage thru both battery post. It is possible that I have a bad ground, your guys can give an idea where to look for.
_____________________________
Jairof [align=right]
[/align]
Old Feb 18, 2008 | 09:59 PM
jairocol's Avatar
Default RE: Electrical issue with my discovery
It is me again about my electrical issue. I checked the new alternator for grounding and I found out that it is not connected to ground. The Mechanic who changed the alternator did
not connected the cables correctly after the repair. I am not sure if ground is the one of the middle (center) or the one of the button.
Note: when I checked the voltage while the car was running itpresented 6 volts on the center and 6 volts on the lower connectors.
Please tell me if I should connect ground to the middle or to the lower connection.
Thank you for checking out.
Old Feb 19, 2008 | 07:40 AM
greg409's Avatar
I don't have my disco home today, but if your asking to connect the ground to an electrical terminal - DO NOT
The ground connects to a mounting point for the alternator (against the aluminum housing, and then to frame or body probably near where the (-) cable from the battery connects.
The electrical connectors are for Positive connections & grounding them WILL break something (bank account?)
Old Feb 19, 2008 | 05:16 PM
jairocol's Avatar
Thank you Greg,
Jairo
lipadj46
Dec 15, 2009 07:52 PM
mrsharp
Oct 29, 2009 09:22 PM
NATEDOGG
Oct 14, 2009 02:02 PM
toms_disco
Defender
Jan 14, 2009 06:05 AM
Strider
May 21, 2006 11:57 AM
