Sponsored by: CARiD
Electrical Problem
Old May 20, 2013 | 08:52 PM
machinetech's Avatar
Default Electrical Problem
Took out Sony radio and reinstalled original rover radio, must have pinched a wire as 20 amp fuse blew. Replaced fuse and checked all others. Lost dome light with door switch and slide switch also radio light not working. Looked at rave manual looks like controlled by MFU on fuse box. Anybody agree with problem.
Old May 20, 2013 | 09:37 PM
Agree on dome light - did you also check fuses and fuse links (bolt in fuse) under hood?
Old May 20, 2013 | 11:09 PM
Default reply to moderator
Yes did check them all. Thanks will track down the mfu
Old May 21, 2013 | 12:32 AM
It is a plastic box stuck on the back of the fuse panel under the dash. I don't see it having anything to do with radio, but it controls the interior lights. Does radio have a fuse on back? Also hope you hooked up both antenna leads to radio, my PO just plugged in the "FM" and not the AM/FM.
jcarr
Feb 4, 2007 07:14 PM
IJDICAO72
Jan 24, 2007 09:22 AM
loic
Jan 7, 2007 11:15 PM
socrazy2992
Sep 14, 2005 06:06 PM
My98disco
Aug 4, 2005 01:21 AM
