Sponsored by: CARiD
Engine knock/catalytic converter
Old Oct 1, 2009 | 06:35 PM
CampCobb's Avatar
Default Engine knock/catalytic converter
2000 Landrover Discovery II 4.0
91k miles
engine is making that notorious knocking noise under the vehicle. Knocks when engine is cold or warm. I crawled under the vehicle and it really seems to be coming from the cat. When I tap on cat with hammer, I can't here any rattle or corrosion. My question is, in the cases where the knocking comes from the cat and sounds like a knock, will the knock increase with rpm's? I can only here it with windows down or I'm outside the vehicle, if that tells you the volume of the knock. thanks for any info.
Old Oct 1, 2009 | 10:34 PM
zs&tas's Avatar
3rd Gear
hi, ive never herd of a knock from a cat ? usually a rattle or meow from them, my guess is that theres a knock in the engine but the cat / exhaust system is just amplifieing the sound ?
my rule is if its quiet in the car dont worry about it ! but im used to driving older stuff with funny sounds HaHa good luck hope this helps.
Old Oct 6, 2009 | 03:46 PM
EVN137's Avatar
Camp
have a look at the heat shield of the catalytic converter. Sometimes, the welding gives out
and it rattles as a result. Will post pics in Discovery forum.
EVN137
Old Oct 7, 2009 | 09:27 AM
Turn your engine off, then hit the cat, if it rattles, it is shout and in need of replacement.
If it sn't the problem it could be a broken flex plate or low end bearing issue.
jwmstang
Aug 4, 2022 02:30 PM
JKK
Mar 4, 2006 01:29 AM
arocena409
Feb 13, 2006 01:08 AM
SUMOSINO
Feb 9, 2006 10:04 AM
mgm777
Jul 27, 2005 05:01 AM
