Sponsored by: CARiD
Engine Management Help
Old Apr 5, 2013 | 12:07 AM
Sounds like a plan.
Old Apr 5, 2013 | 02:45 AM
KigomaSteve's Avatar
Hey Buzz. I checked wires green/yellow and green/ brown behind the interior fuse box. both have 12.7 volts in position II. they are both coming from the same connector. I have 12.7 volts to fuse 14 and I feel the relay kick in when I go to Position II. I'm still at a lose!!!!!
Old Apr 5, 2013 | 08:01 AM
What about immobilization and alarm? What is the red LED on the dash cluster doing?
From the RAVE:
Input/Output
The LED has a dedicated signal from the BCU to indicate the status of the following:
Alarm armed: The LED flashes at 10 Hz with a 50:50 duty cycle for 10 seconds, after which the LED flashes 50 ms on, 2 seconds off until the state of the system changes.
Engine immobilised: If the engine is immobilised and the ignition is on, the LED is illuminated continuously. If the engine is immobilised and the ignition is off, the LED flashes 50 ms on, 2 seconds off.
Alarm tampered: If the alarm has been triggered, the LED flashes at 10 Hz with a 50:50 duty cycle.
Handset battery low indicator: If the handset battery is low, the driver's door is open and the ignition is switched
off, the LED flashes two pulses of 50 ms on, 50 ms off, every 10 seconds.
Perhaps also the sync between the BCU and the ECU have been lost. I'm not sure if the Hawkeye can reset this, or if you must lock/unlock with a key fob multiple time.
Old Apr 5, 2013 | 08:53 AM
Hey Buzz. Yes that was my first consideration. The immobilization works as prescribed. I will try with the key multiple times to see if results are different. I will also look on the HawkEye to see what state it in and try to reset.
Old Apr 5, 2013 | 09:15 AM
jafir's Avatar
The hawkeye as of version 5 cannot sync the BCU and ECM. It can tell you the state of immobilizer.
Old Apr 5, 2013 | 11:51 AM
Can't sync, went thru it all, Everything works ok. immobilization and alarm works fine. Still no spark. CKP is working, I'm getting RPM on live Data. I even checked MAF for power Checks good, 5 volts position II. Just don't know at this point.
Old Apr 6, 2013 | 05:21 AM
Buzz I just put my finger crossed the gap of the spark plug and I do get some pulsing, very small but not enough to get a spark. what are your thoughts?
Old Apr 6, 2013 | 05:26 AM
High resistance in 12 volt lead to coils, would have to measure at the connector (be sure it is clean) to the coils. If possible, use a tail light bulb to make a load on the connection, bulb should glow brightly. A high resistace connection can read "good" with a volt meter, until a load is applied to it. Equally, a high resistance connection from coils to ECU would also cause this, you have moved a lot of connectors.
Ignition coils, or wiring to them. If you still have an old coil and wire, you could use them to test for spark.
Might be something strange, like the bonding jumper from engine block to chassis. That can be duplicated by using a battery jumper cable to attach to frame and metal on engine.
Old Apr 8, 2013 | 12:43 AM
Buzz, I did what you you said on the above post. went first to the coils. Pulled off L/H connector first, tested the 3 pins with the multimeter and found 11.9 volts in the center pin. Then I test with a brake lamp 12 volt bulb with key in position II, Got (NOTHING), and nothing from the other pins. Now I Started to Smile. Then I went to the R/H side of the coils pulled off the connector and tested with the multimeter first. I got 12.7 volts from the center pin, then tested with the brake bulb and the brake lamp lit up brightly. then went back to the L/H connector and now I'm getting good power from the center pin, with the brake lamp bright as day. I cleaned both connectors with electric cleaner, reconnected both connectors to the coil, ran jumper cables to the engine block and to chassis, and IT STARTED right up. YES, YES. but tell me why? Don't get me wrong I'm very happy, but I feel like there is something leerking behind me.
Old Apr 8, 2013 | 01:03 AM
A loose wire perhaps. Wires that are loose, or wires that have rubbed thru inslation and short out from time to time can be the "devil" to find. A high resistance connection (corrosion) can make the volt meter read, but once a load is introduced that same reading will drop off. The corrosion acts like a larger resistor in series.
Near me a young preacher was assigned to a new church. After his first sermon, he greeted everyone as they left the church. A young boy walked up and handed him a coin. When the preacher asked why it was not placed in the collection plate, the boy said "I wanted to give it to you personally". When asked why, the boy replied "Because my Momma said you are the poorest preacher we have ever had here!" Hope that brings a smile to you while you do good work in a distant land.
BTW, many of us have to look up where Tanzania is, I happen to listen to BBC Africa each evening, and hear all about goings on in Niarobi, Kampala, in Kenya to your north. Where in Tanzania are you? Post some photos from time to time, may of us are only armchair adventuers, and would love to be able to drive out Rovers somewhere besides expressways jammed with cars on the way to crowded parking lots.
