Sponsored by: CARiD
Engine Management Help
Old Apr 8, 2013 | 10:20 AM
  #21
KigomaSteve's Avatar
Buzz, we are as far west as you can go in Tanzania, along lake Tanganyika in a town called Kigoma. Our family go into the southern region to reach unreached people groups. our mission start were the road ends. Thank for all your help. It was nice having someone on the other end of the world helping out. Again thank you for your ministry. out here in the bush their was no one who new what to do. I"m glad I found this forum. Here is a link to our web site it will take you to the media of it. Touching Nations Today, INC / Welcome / Welcome
Old Apr 8, 2013 | 10:55 AM
  #22
I have a pal who took a surplus military boat, made a huge floating house boat out of it, designed to motor slowly up the shallow river areas along the coast of South America, to take a floating church for out reach to the local fishing villages.
Of course, back here in the States, we have plenty of churches, but not enough voices inside. Many people in my country question God, and treat their political party like a religion, which seems backward to me.
Old Apr 9, 2013 | 12:11 AM
  #23
Buzz. I know what you mean. Anywhere from two to three months out of the year, My wife and I come back to the states to get supplys and we travel thru out the States letting people know what (He) (God) is doing in Africa. Our home is in Brooksville Florida, about and hour north of Tampa.
Old Apr 9, 2013 | 12:19 AM
  #24
Small world, I spent several years in Palm Harbor on a project....
Old Apr 9, 2013 | 08:52 AM
  #25
Were can I get a code book? Got some codes I want to iron out.
Old Apr 9, 2013 | 10:22 AM
  #26
Go back to the second post on this thread and there is a link where you can download the Bosch ECU manual which has all the engine codes and how they are created. Your copy of the RAVE also has the codes, you can use the search feature in Adobe pdf reader to go to them in the workshop manual. There are also codes that can report for the transmission.
Old Apr 15, 2013 | 12:33 AM
  #27
Hey Buzz, I rewired Green/Yellow and Green/Brown from the interior fuse bow to the coil, and rewired the Red, Pink/Black, Blue/white, Blue from the ECM to the coil. came out awesome. Went to fire it up, no start. went back to the coil checked for power to center pins, it checked GOOD. reconnected the connectors to the coil and it fired right up. All is good now in Tanzania. BUT after 15 Mins the Idle was hard to keep above 500 RPMs. it will run awesome with it that 15 mins. once the truck stalls, the only way I can get it restarted is to disconnect connectors from the coils, check for power, reconnect connectors and it will fire right up. then great for 15 to 20 then again has a hard time with Idling. I need some words of wisdom.
Old Apr 15, 2013 | 12:55 AM
  #28
I suspect that at the 15 minute mark there is a switch to closed loop fuel management by the ECU, where the O2 sensors are in control of things. Also, the IACV (idle air control valve) controls idle speed, it may need to be cleaned (carb cleaner).
James Kirk
Apr 6, 2014 03:53 PM
James Kirk
Apr 5, 2014 12:19 PM
LANDROVER714
Sep 12, 2013 05:49 PM
Savannah Buzz
Feb 28, 2013 07:47 AM
