Sponsored by: CARiD
engine noise ?? Whats else to try
Old Aug 11, 2010 | 06:20 AM
Gr8lite's Avatar
Default engine noise ?? Whats else to try
1995 Range Rover country LWB , 125k miles
developed a tick or clatter a week ago. Sounded like lifter noise , lifters were replaced. Noise still there. Possibly rockers or rocker shafts worn? Swapped rockers and shafts from a good running , quiet, '95 4.2. Noise still there. Start the engine cold , approx 10 - 15 mins the noise starts. Sometimes goes away, comes back, etc... Shut it off for 15 mins , start up same deal.
Thoughts? A bad lifter ? The inside of this engine is clean , clean , clean. The previous owner claims only synthetic, it looks like it.
Thanks to all!
Old Aug 11, 2010 | 08:43 PM
Could be a bad timing set, bad cats, oil is the wrong viscosity, spark plug wires arching...
Old Aug 11, 2010 | 09:35 PM
OFFROVIN's Avatar
I suffered the same problem. I was convinced it was a lifter. It turns out it was a cracked exaust manifold. When it was cold it leaked. When it warmed up (between 1-3 minutes) the expansion closed the crack and it quieted down. I replaced the mainifold and gasket....problem solved. This was the first time in my life that I fixed a bad lifter with an exaust manifold and gasket. ; )
Old Aug 12, 2010 | 10:36 AM
Gr8lite's Avatar
How about a valve guide , slipping in the head. The sound is perfectly in time with the action of the valves.
RoverZebra
Dec 8, 2012 04:27 PM
Helen20
Nov 2, 2011 03:06 AM
farmer2010
Defender
Jul 17, 2010 08:34 AM
andytaylors
May 27, 2010 11:59 PM
97 Disco
Apr 30, 2005 03:07 PM
