Sponsored by: CARiD
Won't start in the heat
Old Jun 26, 2010 | 09:16 PM
jasonabarrett's Avatar
Default Won't start in the heat
I have a 96 Disco and it will not start once it gets hot, if it is hot outside. It will start if I shut it off and start it back up immediately, but if I let it set for 10 minutes or so it will not start until, I open the hood and let the engine cool down. The motor is not running hot, I have replaced the Fuel Temp Sensor, fuel and air filter, all fluids are full and fresh. It starts just fine even with a hot motor if it is below 80 degrees. It is very frustrating Thanks for any help!
Old Jun 27, 2010 | 08:52 AM
ibis1's Avatar
Talking Won't start hot?
jason,
I am assuming it's cranking and not starting and not a "no crank" condition. The first thing you must do is isolate if the problem is a "no spark" or "no fuel" or both condition. If it's both, you probably have a bad CKP (crank) sensor. It could be vapor lock, although that's not common with FI vehicles. Determine which it is and we can work from there. ibis1
Old Jun 27, 2010 | 10:39 AM
Thumbs up won't start in heat
The problem really acts like an old fashion vapor lock situation, but I was not aware that fuel injected motors still did that. I am still getting spark just not fuel and when i do get fuel it sputters for a hundred yards or so until it gets a full dose of fuel and kicks in fine and runs like a champ after that. Any suggestions to try to fix vapor lock in modern times, it's worth a try?? Thanks!
Old Jun 27, 2010 | 11:54 AM
ibis1's Avatar
Talking Hot start?
jason,
Get a good jumper wire and the next time it acts up, jump (battery voltage) to terminal number 1 of the inertia switch connector. (connector off) This applies full battery voltage to the fuel pump, if it runs fine you have a excessive voltage drop in the fuel pump circuit, which now would be easy to isolate. ibis1
Old Jun 27, 2010 | 12:53 PM
Ibis I dont want to sound stupid but where is the inertia switch connector located? I am sure I can find it if you point me in the right direction and I use some web resources. Thanks so much Jason
Old Jun 27, 2010 | 02:29 PM
turbogregtn's Avatar
mine is doing the same thing i'm trying to run down the problem
Old Jun 27, 2010 | 10:13 PM
ibis1's Avatar
Talking Inertia switch
jason,
The inertia switch is mounted to the firewall on the passenger side of the vehicle. It's a 3 way connector with 2 white/purple wires. ibis1
Old Jun 28, 2010 | 08:27 AM
OzarkRover's Avatar
Wink
Originally Posted by jank8431
There is a fuse in the glow plug circuit. It's located on the firewall, behind the engine. Looks like a black plastic box, about two inches by one. If you open it, you should see a strip of lead inside. If this is broken, no glow plugs. You can get replacement strips from Mercedes dealers.
Whaaattt????
Glow plugs....Mercedes dealer.....
I thought the 96 DI was a gas burner, and if it is then glow plugs are a non-issue...besides, if it is a diesel engine they like to start when warm...it's cold conditions when you would need the glow plugs anyway...just saying???
Old Jun 28, 2010 | 04:21 PM
ibis1's Avatar
Talking Diesel?
Originally Posted by OzarkRover
Whaaattt????
Ozark,
I didn't know what to make of that. I thought he must be joking, we're talking about checking for spark and he's talking glow plugs. They use a lot of diesel's in other markets, he may have flown right past my post. Keep working on the Old Girl. ibis1
Old Aug 13, 2010 | 06:23 PM
97disco's Avatar
3rd Gear
my 97 disco is doing the same thing, i'm still trying to figure it out myself. although i did find that if you depress the schraeder in the fuel line, it will release the vapor and will start up afterwards. be carefull though, hot vapors and hot engine could be bad...
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jan 17, 2014 09:19 PM
jmason
Nov 17, 2013 06:39 AM
Mountain State Rover
Jun 29, 2013 02:06 PM
asmcmillin
Jan 23, 2005 01:18 AM
