Sponsored by: CARiD
Engine Oil
Old Jun 12, 2007 | 10:24 PM
dalfier's Avatar
Default Engine Oil
My 99 4.6 HSE has 100k miles. The previous owner used straight 10w30 oil. Is it too late to move to synthetic or synthetic blend? Or should I continue using regular motor oil?
Old Jun 13, 2007 | 08:27 AM
Default RE: Engine Oil
What state do you live in, do you have freezing winters?
10W/30 is fine, you can go heavier if you live in the 90 to 100 degree states, and if you want to switch to a blend or synthrtic, it is never too late.
I would suggest using a partial synthetic, I use Castrol's 10W/30 here in Colorado, used to use their 20W/50 when I live and played in the high deserts of California.
Two thoughts for you, do a good engine flush to clean out the engine and make sure to use good quality oil filters like the K&N 3001 or a Mobil 1 filter.
Have fun,
Mike
Rufflyer
Mar 22, 2015 10:13 AM
Beaulim
May 2, 2014 08:03 PM
Paul3221
Nov 25, 2013 12:12 PM
rikdburns
Feb 27, 2010 06:37 PM
shagybruce
Feb 8, 2007 02:52 PM
