exhaust leak!! any help would be great!!!!!!
so i have replaced my manifold to pipe flange gaskets 3 times now and my passenger side keeps failing and throws 22 different codes from miss fire o2 sensors and system too lean. so i figured out the problem and tightened the passenger side flange gasket check engine light went off in about 20 miles and was driving great! then at about 60 miles started running ruff and throwing codes again (i am positive that the flange gasket is the problem). so i took off my exhaust system fixed a broken stud (on the passenger side) and replaced the gaskets 3 times now. has any one had a problem like this or heard of one? or should i do it again and tighten pasenger side first? im kind of lost what else could cause this? thank you for any help you can provide.
Newroverguy
01-26-2011 10:29 AM
FightOnUSC79
07-20-2010 03:15 PM
Jwilk
01-03-2008 09:46 AM
