Sponsored by: CARiD
exhaust leak!! any help would be great!!!!!!
Old Mar 26, 2014 | 07:11 PM
dobe1canobe's Avatar
Default exhaust leak!! any help would be great!!!!!!
so i have replaced my manifold to pipe flange gaskets 3 times now and my passenger side keeps failing and throws 22 different codes from miss fire o2 sensors and system too lean. so i figured out the problem and tightened the passenger side flange gasket check engine light went off in about 20 miles and was driving great! then at about 60 miles started running ruff and throwing codes again (i am positive that the flange gasket is the problem). so i took off my exhaust system fixed a broken stud (on the passenger side) and replaced the gaskets 3 times now. has any one had a problem like this or heard of one? or should i do it again and tighten pasenger side first? im kind of lost what else could cause this? thank you for any help you can provide.
Old Mar 26, 2014 | 07:23 PM
if i have an alignment issue does any one know of an easy fix? also can i try using 2 gaskets or would that be bad?
Old Mar 27, 2014 | 05:53 PM
automagic's Avatar
That's a strange one! I wouldn't try two gaskets, it would probably be worse. You could try getting some exhaust gasket paste and sticking a load of that on with the gasket?
In the same way you might put rtv sealant on a paper water pump gasket...
Old Mar 28, 2014 | 06:53 AM
drowssap's Avatar
have some one hold a rag over the exhaust while it is running, if you have a leak you will hear the back pressure pissing out under the truck
Perfectphoto
May 31, 2019 08:27 AM
Newroverguy
Jan 26, 2011 10:29 AM
FightOnUSC79
Jul 20, 2010 03:15 PM
Chillbred
May 5, 2008 07:27 PM
Jwilk
Jan 3, 2008 09:46 AM
