Sponsored by: CARiD
External lights not working
Old Nov 7, 2009 | 08:39 AM
vindicator's Avatar
6th Gear
Default External lights not working
Hi,
my disco 1 has non working tail lights and front lights as well. Fuses are fine. I am talking about those lights that you turn on by switching the light lever to the first position. The headlights work and so do the brake lights, I use fog lights at night in the rear to be seen. I checked the bulbs too. Any ideas? Thanks
Old Nov 7, 2009 | 08:45 AM
Sounds like your headlight switch has failed.
Old Nov 7, 2009 | 12:09 PM
vindicator's Avatar
6th Gear
Disco Mike, sometimes the little red light on the rear bumper next to the signal light on the left comes on and sometimes it doesn't. The other one never does. So should I look at the switch lever?
Old Nov 7, 2009 | 12:13 PM
If you have checked and cleaned all the sockets and connections, and have run a test probe to verify power to those lights, no power to me means a bad switch which is kind of normal for Disco's.
Old Nov 7, 2009 | 12:31 PM
vindicator's Avatar
6th Gear
Thanks Mike, I haven't checked all sockets per say, I assumed one bad socket wouldn't mess up the entire circuit. I will check the switch though, thanks.
Old Nov 7, 2009 | 02:04 PM
vindicator's Avatar
6th Gear
And the dash is lit up when the light switch is on in either position, would that mean the switch is fine? What a puzzle..
tsuyoi
Sep 22, 2020 10:37 AM
abran
Dec 7, 2019 08:07 PM
booper169
Mar 20, 2019 09:37 PM
zigzag3141
Apr 13, 2017 12:47 AM
ajh
Audio/Visual Electronics
Sep 2, 2006 01:20 PM
