Sponsored by: CARiD
fan hits shroud
Old Oct 14, 2009 | 07:41 PM
shmassey1@roadrunner.com's Avatar
Default fan hits shroud
I have a 1991 Land Rover and the coolant system warning light signalled a problem. I added some coolant, but not the warning light still flashes, and the fan now hits the radiator shroud pretty severely -- so it's not driveable. Any idea what could be wrong or how to fix it? I tried adjusting the shroud, but it can't really be adjusted much.
Old Oct 15, 2009 | 08:53 AM
Check your motor mounts, the drivers side, and or the passengers side are most likely broken allowing the engine to move.
Old Oct 27, 2009 | 04:34 PM
hlc's Avatar
hlc
4th Gear
also check free play in the fan clutch and water pump.
buick215
Dec 14, 2014 04:10 PM
Rover_Hokie
May 15, 2013 08:17 PM
darrengj
Mar 5, 2013 09:46 PM
photocrimes
May 30, 2011 12:45 PM
05LandRover
Sights N Sounds
15
Feb 26, 2007 05:49 PM
