Push/Twist/Screw for fan shroud
Old May 12, 2013 | 11:06 PM
Rover_Hokie's Avatar
Default Push/Twist/Screw for fan shroud
Anybody have a source for these special fasteners to hold the fan shroud in place on the D2 with the phillips screw head?
Old May 13, 2013 | 02:19 AM
I dunno, but here is why you want to be careful. The plastic boss the fastener goes into is not very stout, cracks and then leaks, new rad time.
Attached Thumbnails Push/Twist/Screw for fan shroud-d2-rad-top-scew-crack.jpg
Old May 13, 2013 | 07:36 AM
Dealership or used parts like from Paul Grant.
Old May 13, 2013 | 07:56 AM
drowssap's Avatar
are you talking about the plastic screw/rivet that hold the shroud on?
Old May 13, 2013 | 08:02 AM
I looked it up in a Microcat and it shows P/N FS106127L (screw-flanged head, M6 X 12 MM).
An on-line one is http://lrpart.ru, select English option.
Old May 13, 2013 | 10:58 AM
jafir's Avatar
Are you talking about the dzus, 1/4 turn type fastener? If so, hold on to your wallet. They are stupid expensive. Do a search, I've posted the part numbers before.
Old May 15, 2013 | 08:17 PM
Yes, those are the ones in question.
buick215
Dec 14, 2014 04:10 PM
darrengj
Mar 5, 2013 09:46 PM
photocrimes
May 30, 2011 12:45 PM
shmassey1@roadrunner.com
Oct 27, 2009 04:34 PM
Aquaholic
Mar 6, 2007 06:55 PM
