Sponsored by: CARiD
fan issues
Old May 19, 2015 | 11:41 AM
machinetech's Avatar
Default fan issues
97 Discovery 1 A.c. dont run also also both cooling fans dont turn on when putting on defrost. Also when you push in button to turn on air light on switch doesnt come on. I checked fuses all check ok and also jumped ac clutch with 12 volts and clutch plate ran and started blowing cold air. Any suggestions what to go a after next will be appreciated.
Old May 21, 2015 | 12:15 PM
justryan's Avatar
If the fuses are ok .... clean/check the connections to compressor , fans ,
( are you referring to the clutch plate in the compressor ? )
Old May 21, 2015 | 07:31 PM
yes clutch plate is not turning unless I hot wire plug
Old May 22, 2015 | 07:44 AM
jimvw57's Avatar
could be low on refrigerant, some vehicles will not run the AC if the outside temp is below a certain temp.
Old May 22, 2015 | 09:48 AM
drowssap's Avatar
Find the low pressure switch for the system and jump it out. if everything works its low On gas
Old May 22, 2015 | 11:03 AM
justryan's Avatar
Be sure to get the system checked for leaks , if its that ? or else it will be back to square one after a while ...
also check compressor oil ..
Old May 26, 2015 | 06:53 AM
TOM R's Avatar
Dash button can go bad, if you end up being low on r134a and have rear a/c, the metal line in drivers rear wheel well goes bad, rots through
jafir
Feb 10, 2017 11:08 AM
Eak69
Apr 6, 2010 04:50 PM
rover1978
Sep 26, 2009 09:05 PM
jmt
Jan 14, 2008 05:01 PM
