Fault Codes
Hi-
Just bought a 2001 Discovery Land Rover with 91000 miles. Two days after buying I am getting some fault codes-P1774, P1668, and P1171.
I have tried looking them up but come up with info. from the Ford site and Audi site.
For P1774-I found Hydraulic Pressure Sensor 1 to low
P166-I found Open/Shorted EF or FDCS open IDM ground
P1171-I found Throttle Actuation Potentiometer sign 2. Range/Performance.
If these are correct can someone tell me what they mean and how important to get fixed.
Thank you.
Carol
Thank you.
Carol
Carol
I was only able to find the 1774 fault which state both banks running too lean.
Did you buy this truck from a dealer, if so I would go back to them and insist they correct the problem.
Mike
Mike
P1668
Land Rover
Anti-Theft Alarm serial link faultDrive cycle A:Signal out of range - above maximum
P1171
Land Rover
System Too lean, Bank A & Bank B
That's what I found. Not sure where to go from there.....
mcvayrover
Jan 8, 2024 11:50 AM
kbarker27
Oct 13, 2023 04:03 PM
06Range
May 8, 2013 09:01 PM
