Sponsored by: CARiD
Fault Codes
Old Aug 1, 2007 | 10:11 PM
me3ps's Avatar
5th Gear
Default Fault Codes
Hi-
Just bought a 2001 Discovery Land Rover with 91000 miles. Two days after buying I am getting some fault codes-P1774, P1668, and P1171.
I have tried looking them up but come up with info. from the Ford site and Audi site.
For P1774-I found Hydraulic Pressure Sensor 1 to low
P166-I found Open/Shorted EF or FDCS open IDM ground
P1171-I found Throttle Actuation Potentiometer sign 2. Range/Performance.
If these are correct can someone tell me what they mean and how important to get fixed.
Thank you.
Carol
Old Aug 2, 2007 | 11:01 AM
Default RE: Fault Codes
Carol
I was only able to find the 1774 fault which state both banks running too lean.
Did you buy this truck from a dealer, if so I would go back to them and insist they correct the problem.
Mike
Old Aug 2, 2007 | 02:30 PM
okdiscoguy's Avatar
P1668
Land Rover
Anti-Theft Alarm serial link faultDrive cycle A:Signal out of range - above maximum
P1171
Land Rover
System Too lean, Bank A & Bank B
That's what I found. Not sure where to go from there.....
Old Aug 22, 2007 | 02:31 PM
sideburns's Avatar
clear codes see what comes back,don't worry about the p1668,...the p1171 could be a vacum leak or faulty maf sensor,hit it...needs one
06Range
May 8, 2013 09:01 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
