Sponsored by: CARiD
Freelander- Love it
Old Jun 5, 2010 | 05:36 AM
davodave's Avatar
4th Gear
Question Freelander- Love it
I recently purchased a Freelander 2.5 v6. I love the feel of the car but it has an annoying vibration- I think from the prop shaft area. I only get this when I accelerate and it does not matter what gear it is in. Any ideas whats wrong?
Davodave
Old Jun 5, 2010 | 08:15 AM
Rovin4life's Avatar
frt axle shafts are loose on the inner cv joint.
if you think its the propshaft, take it out of the vehicle and drive around.
Old Jun 5, 2010 | 08:34 AM
davodave's Avatar
4th Gear
I had a new front prop shaft fitted recently as i was told this was the problem but it did not fix it. It improved a little bit. I have not replaced the rear propshaft or the propshaft bearings as I was unsure if this would fix it. I would have to import them from the UK to Australia as they are so expensive here. I had the rear propshaft removed but there was still vibration. You mention the front axle shafts could be loose - any way a novice can test this?
If replacing the rear prop and bearings would fix it for sure then I would probably go for it. What do you think?
uncommonsavior
Sep 10, 2009 11:02 AM
rover ryan
Jul 4, 2005 01:12 PM
rover ryan
May 23, 2005 01:14 PM
Off Topic
Apr 28, 2005 04:02 AM
dma3
Apr 2, 2005 02:55 AM
