Freelander Won't always start
RE: Freelander Won't always start
fuel pump relay sounds like a good starting point. They can get weak over time and work sometimes and not others. The biggest recommendation I can give is to check the freelander section and see if they have help in the forum, or faq, or search. I am making one presumption and that is that during the start sequence everything else seems ok. It cranks even when it won't start. The other quick thought is the fuel sending unit sensor. hope it helps. gotta love a rover. duboff
i'm having this exact same problem. i've had a local shop replace a couple different sensors. the next one they want to replace is the cam position sensor. it's going to be like 130 bucks plus labor! i'm going to try to see if the fuel pump relay is actually the problem.
VikingDiesel
02-24-2009 05:38 PM
