Sponsored by: CARiD
Front brakes seizing
Old Dec 31, 2012 | 08:27 PM
coastie's Avatar
Default Front brakes seizing
I recently replaced the Master cylinder along with a new brake hose on the left front caliper. Today I went driving around and suddenly the truck started to slow and the more gas I applied the slower it went. I pulled off and got out to look under the hood and saw the left front wheel steaming (it was raining). I put my hand near the rotor and could tell it was very hot and the rotor had turned blue from heat. I looked over at the right front wheel same thing. Rear wheels were warm but not hot.
Thinking it was the ABS acting up I disconnected the 5A fuse from the fuse block and everything was fine with the brakes.
I just went out again and after about ten minutes driving same thing the front brakes locked up again. The fuse was still out of the ABS circuit. I turned off the engine and left it set for a minute and again the brakes were back to normal.
Any ideas? I'm stumped at the moment.
Old Dec 31, 2012 | 10:58 PM
You did not use a Land Rover master cylinder.
You must, this happens each and everytime, I have no idea why.
You want to remove the ABS PUMP fuse from under the hood not the one under the dash.
Old Dec 31, 2012 | 11:04 PM
ihscouts's Avatar
Hey, Happy New Years Phil....
Old Dec 31, 2012 | 11:25 PM
Thank's Doug, Happy New Year to you to my friend.
Old Dec 31, 2012 | 11:35 PM
coastie's Avatar
You may be right. I got to thinking about it and the M/C did not seem to sit flush against the booster. I'll check tomorrow could be just enough out of alignment to cause binding of the booster.
Old Jan 1, 2013 | 11:50 AM
Let us know if you get it sorted out.
I have been looking for the cure for the non LR master cylinder for some time now.
Old Jan 2, 2013 | 02:10 PM
coastie's Avatar
One to Round Two of Brake seizing:
I pulled all the fuses (3?) related to the ABS, re-aligned the master cylinder in relation to the booster shaft. Everything seem good. Took it for a drive on the highway - locked up again. I pulled off, turned off the ignition and started to tap on the M/C, Secondary and ABS module. Suddenly I heard a "CLICK" somewhere and checked the brakes and they are back to normal. So I head home and about five miles later, brakes are binding again. Pulled off, opened the hood, starting whanging again no luck. Turned off the ignition and a moment later "CLICK!" back to normal.
What is the clicking? Does the secondary cylinder have a solenoid? Or is it the ABS again?
raid13
Defender
Jul 29, 2014 08:48 PM
Flip21
Dec 11, 2013 07:08 AM
FightOnUSC79
Nov 26, 2010 09:43 AM
Jull
Nov 3, 2009 09:51 AM
1eyescooter
Feb 1, 2007 11:12 AM
